I have a slightly unpleasant task (see VB .NET) of working with a .NET API to interface to some vendor software.
Is there a path for maybe ditching .NET and using an available Ignition function? I'm starting to look at custom modules in Ignition, could this be a way?
Any suggestions would be appreciated.
-thanks
What kind of .NET API are you talking about?
You have some DLL(s) / .NET assemblies or it's some web service written in .NET that you're just calling?
It's a .NET assembly that I'm pointing to. The vendor may have a DLL option as well.
Mmm, well neither of those options are any good for integrating with Ignition.
A DLL, in the best case, is usable from a custom module if you know what you're doing with JNI/JNA.
Makes sense. Thanks for your advice.
