I set up security on a clients ignition gateway and am having some issues with it. At first I set up a manager role (access to everything except the gateway config), then set on the gateway config any writing to PLCs needed to be done with at least the manager role. It was working fine.
With more thought, I removed that rule and changed it so its only project wide in case they did other projects on that gateway. The problem that I have now is that every once in a while, no matter what log in I am using (manager or admin) I will get an error that says "Error Writing to node, this account does not have write access". Those aren't the exact words but that is the idea. The thing is, that if I just keep hitting accept or go out of the screen and come back in, it will let me write to the PLC. I am going to try to restart the gateway at some point when I can get some downtime and maybe that will fix it but until then, has anyone run into this issue?
