Chrome will not be able to run your project in applet mode, as they have dropped support for Java applets. Firefox will run the applet, but only if you have the right addon installed. If you go to your Add-ons Manager in Firefox, you should see an item titled ‘Java™ Platform’. Make sure that is set to ‘Always Activate’. If it’s not there, you will have to install the Java addon for Mozilla.
