I read this post to help me understand how I can access internal property of a template in one of my GUI components’ script.
I have two properties in a Template, one is Template property called MyIsInactive and the other is Internal property called MyInternalIsInactive.
Let’s give the Template name Templ
Now, in one of my windows I have some Templs and I try to grab the Templs but populating it through its parent component. I make sure that when I populate, I only grab the Templs:
for comp in parent.components:
if not comp.name.startswith('Templ'):
continue
Now, after I grab the Templs, I try to get its properties like this:
val = comp.getPropertyValue('MyInternalIsInactive') #should be False
val2 = comp.getPropertyValue('MyIsInactive') #should be False
print val, val2
But when I print them out, I got
None False
Instead of
False False
Is Internal Property no longer accessible from script module?
