I’m experiencing issues logging into the designer using our IdP. While I can successfully log into the gateway webpage, attempting to log into the designer results in an internal server error.
You will need to look at the gateway logs to see what is really happening.
I figured it out, I misspelled one of the group names in the designer permissions. I am surprised that was the error I received and not a login failure or not authorized error.
