Internal Tag not Updating
Hello All,
im a little lost actually and im not sure if i do something wrong or have some missunderstanding. (Maybe it could be a bug)
Ignition Version : 8.1.2 (b2021020311)
Following situation. I have a Tag that i will monitor on Gatewayside and react to diffrent values
after the script is executed it will write the same tag to a diffrent value. But if i “trigger” this tag
via Vision Client or Designer the value i write into the Tag after the script is executed the
value wont update.
After a while i tried something out and find out that if i insert a sleep of 1 second after script is executed and before the tag is written it works.
Also if i connect via a external OPCUA-Client on exposed Tag Providers and try the same it works.
Example:
Gateway Tag Change Event Script :
Also this is strange that the value on “Edit” is diffrent (the expected value) than
it is shown in Vision Client / Designer Tagbrowser
Thank you for youre help!
Br,
Roland
Can you see if this still happens with 8.1.3? This could be something that got fixed.
Hi Kevin,
its fixed with 8.13 thanks
br,
Roland
