Trying to make a UDT involving composition. I have a Parent UDT called "QATest" that contains several Child UDT's which are a slightly expanded "Real" tags.
I am getting the following error in the Gateway console when creating the Parent tags, and am unsure what it is actually complaining about.
Invalid folder structure for UDT member. Tag cannot be added to hierarchy. Parent details may not be loaded yet, will try again if the udt parent is updated. Info: [name=ProdVolCount, uid:111f208e-583c-47a1-854e-1f820c642da3, parent-uid:150a8523-4081-47ab-b565-544708769d4b]
Strangely i get console errors for only 2 out of the 4 Child tags (ProdVolCount and ProdHrsTarget)
I am passing through Parent UDT parameters to the Child UDT Parameters using {param}, and can verify it works because the OPC Path is built correctly and reading values correctly.
Here is a screenshot of the UDT i'm building.
