Hello,
I’ve developed artifacts for a SOAP webservice using the wsimport command in Java (JRE/JDK 1.8). These are packaged into a module and can be called from within Ignition. If the response is OK (i.e. not an Exception), I get the expected response in Ignition. However, if I try to test a SOAP exception, I get the error:
java.lang.IllegalStateException: java.lang.IllegalStateException: You are running with invalid JAXP api or implementation. JAXP api/implementation of version 1.3.1 (included in JDK6) or higher is required. In case you are using ant, make sure ant 1.7.0 or higher is used - older versions of ant contain JAXP api/impl version 1.2 (in xml-apis.jar). If you want to keep using older ant versions, you have to configure it to use higher the JAXP api/impl versions.
This works fine if I execute this in a non-Ignition Jython environment via Eclipse.
Any help resolving this would be appreciated.
Full stacktrace below.
Java Traceback:
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:404)
at org.python.core.PyObject.__call__(PyObject.java:408)
at org.python.core.PyMethod.__call__(PyMethod.java:124)
at org.python.pycode._pyx29.APIVersion$1(<module:shared.custom.GetVersion>:19)
at org.python.pycode._pyx29.call_function(<module:shared.custom.GetVersion>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:166)
at org.python.core.PyFunction.__call__(PyFunction.java:338)
at org.python.pycode._pyx28.f$0(<buffer>:11)
at org.python.pycode._pyx28.call_function(<buffer>)
at org.python.core.Py.runCode(Py.java:1275)
at org.python.core.Py.exec(Py.java:1319)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:215)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:89)
at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:70)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:476)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:464)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalStateException: You are running with invalid JAXP api or implementation. JAXP api/implementation of version 1.3.1 (included in JDK6) or higher is required. In case you are using ant, make sure ant 1.7.0 or higher is used - older versions of ant contain JAXP api/impl version 1.2 (in xml-apis.jar). If you want to keep using older ant versions, you have to configure it to use higher the JAXP api/impl versions.
at com.sun.xml.internal.bind.v2.util.XmlFactory.createTransformerFactory(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.JAXBContextImpl.createTransformerHandler(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.DomLoader$State.<init>(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.DomLoader.startElement(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.ProxyLoader.startElement(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext._startElement(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext.startElement(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.InterningXmlVisitor.startElement(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.StAXStreamConnector.handleStartElement(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.StAXStreamConnector.bridge(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(Unknown Source)
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(Unknown Source)
at com.sun.xml.internal.ws.message.stream.StreamMessage.readPayloadAsJAXB(Unknown Source)
at com.sun.xml.internal.ws.api.message.MessageWrapper.readPayloadAsJAXB(Unknown Source)
at com.sun.xml.internal.ws.fault.SOAPFaultBuilder.create(Unknown Source)
at com.sun.xml.internal.ws.client.sei.StubHandler.readResponse(Unknown Source)
at com.sun.xml.internal.ws.db.DatabindingImpl.deserializeResponse(Unknown Source)
at com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(Unknown Source)
at com.sun.xml.internal.ws.client.sei.SEIStub.invoke(Unknown Source)
at com.sun.proxy.$Proxy61.getAPIVersion(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
... 26 more
Caused by: java.lang.AbstractMethodError: javax.xml.transform.TransformerFactory.setFeature(Ljava/lang/String;Z)V
... 53 more
File "<buffer>", line 8, in <module>
File "<module:shared.custom>", line 12, in APIVersion
File "<module:shared.custom.GetVersion>", line 12, in APIVersion
