Hello all,
I am using a flex repeater in my perspective project and I bound the instance to a named query. What should be the return format of the instance? Is it json? If yes, I get an invalid key error on json.
I am assuming the error is because of these two properties:
Because when I bound the value of the instance to that named query I do not get these two parameters.
In this case what should be the JSON transform format?
How to capture the value?
return [
{ "instanceStyle": {
"classes": ""
"instancePosition": {}
