Invalid literal for int/float
Can anyone help me get around this? Thanks.
Fail:
Works, same type and value?
when you do the tag read, are you sure its “134” and not "134 " (with a space)?
Yeah, it might be interesting to print the len(raw) you get in the version that fails.
or use
print repr(raw)
There is obviously some unwanted characters in the string. Is is possible to filter it out?
Is it always going to have a x02 prefix and x03 suffix?
Yes, its STX and ETX in the message.
Solved:
raw = system.tag.read("[EtikettTag]SICK/2112/Message").value
raw = raw.strip()
raw = raw[1:]
raw = raw[:-1]
If this is true you can use
raw.strip('\x02\x03')
Else you probably will want to use a regex pattern
import re
raw = re.sub("[^0-9]",'',raw)
raw[1:-1] would work too.
Thanks all! :slight_smile:
