Running on v7.6.2 based on Windows Server 2008 SP2, connected to SQL2012
If I comment out the line that I have isolated by itself, the query works fine - it’s just when that one line is active in the rest of the query that I get the fault listed at the end of this quote
code from query follows after quote
[quote]java.lang.Exception: Error running query:
SQLQuery(query=SET NOCOUNT ON
DECLARE @EID int = 19
select top 100 [Verify_Package_Data].[Index],
[Verify_Package_Data].[Ship_BC] AS “Label Code”,
[Verify_Package_Data].[ScaleSP] AS “sp00”,
[Verify_Package_Data].[ScaleScanBox] AS “Box DimCode”,
–[Scale_Grades].[Weight] AS (cast(’[Scale_Grades].[Weight]’, float(6))*(convert(float(6),0.001))) “Weight”,
[Scale_Grades].[Weight] AS “Weight”,
–(cast([Scale_Grades].[Weight] AS float(8)) * 0.001) as “Weight2”,
(convert(int, [Scale_Grades].[Weight]) * 0.001) as “Weight2”, – Might work, but appears to cause XML parse error on data returned from query
[Verify_Package_Data].[KO_Code] AS “KO Reason Code”,
[Verify_Package_Data].[PackType] AS “1 = Flat, 0 = Ship”,
[Verify_Package_Data].[AvgHeight1] AS “Height 1”,
[Verify_Package_Data].[AvgHeight2] AS “Height 2”,
[Verify_Package_Data].[ExceededSlope] AS “Excess Slope”,
[Verify_Package_Data].[PositionError] AS “Position Error”
from [Verify_Package_Data]
join [Scale_Grades]
on [Scale_Grades].SPOO_BC = [Verify_Package_Data].ScaleSP
where @EID = [Verify_Package_Data].[EID]
order by [Verify_Package_Data].[t_stamp] desc
, database=OEE)@5000ms
On: SLAM_Operator_New.Root Container.tbl_Package 1.Try2
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:316)
at java.lang.Thread.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to read response from Gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:416)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:249)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:244)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:712)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:676)
at com.inductiveautomation.factorypmi.application.gateway.SQLQuery.execute(SQLQuery.java:48)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.execute(QueryManager.java:690)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.access$500(QueryManager.java:663)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:314)
… 1 more
Caused by: org.xml.sax.SAXParseException; lineNumber: 17; columnNumber: 96; An invalid XML character (Unicode: 0x10) was found in the CDATA section.
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:414)
… 9 more
Ignition v7.6.2 (b2368)
Java: Oracle Corporation 1.7.0_25
[/quote]
[code]SET NOCOUNT ON
DECLARE @EID int = {Root Container.dpd_SLAM_Line.selectedValue}
join [Scale_Grades]
[/code]
