You can probably remove the duplicate tags by following these steps
[ul]1. Create a SQLTags export
2. Restart the SQLTags Realtime Provider in the gateway, you only need to Edit/Save
3. Go back to the Designer and refresh the SQLTags Browser
4. Delete any tags that show up for the provider you are using
5. Repeat steps 2 through 4 until no tags are returned[/ul]
Make sure you are only deleting tags from the SQLTags Realtime provider you are using.
[quote=“Greg.Simpson”]You can probably remove the duplicate tags by following these steps
Make sure you are only deleting tags from the SQLTags Realtime provider you are using.[/quote]
This issue is something that pops up from time to time. The developers are well aware of it, and working to resolve the issue. It is an issue that happens very infrequently.
