I have finally managed to write a script module that opens a page, grabs the report viewer as a pfd, saves it and then closes the window. I am running this off of a button on screen. Everything I read regarding this tells me I should use the invokelater function but if I have this at the bottom of the script I get the error message:
[quote]Traceback (innermost last):
File “event:actionPerformed”, line 1, in ?
ImportError: Error loading module test3: null
at org.python.core.Py.ImportError(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptModule.loadModule(ScriptModule.java:46)
at com.inductiveautomation.ignition.common.script.ScriptPackage.__findattr__(ScriptPackage.java:59)
at org.python.core.PyObject.__getattr__(PyObject.java)
at org.python.pycode._pyx68.f$0(<event:actionPerformed>:1)
at org.python.pycode._pyx68.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:391)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:139)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:247)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy1.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
Ignition v7.2.2 (b6567)
Java: Sun Microsystems Inc. 1.6.0_20[/quote]
Below is my file, if I remove the # from the invokelater line it errors, without the invoke the code works perfectly
[code]def test():
import system
open window with report on it
system.nav.openWindow('AP7_Power_Reports/Biscuit_Report')
declare “window” as the window name. You cannot just use event.source.parent etc
window = system.gui.getWindow('AP7_Power_Reports/Biscuit_Report')
declare “report” as the Report Viewer (same reason as line above)
report = window.getRootContainer().getComponent('Report Viewer')
declare “data” as the bytes for PDF of the report
data = report.getBytesPDF()
declare “path” to be where the writefile ‘path’ will be
path = "C:\Documents and Settings\elec\Desktop\Energy " + window.getRootContainer().getdate + ".pdf"
if path != None:
system.file.writeFile(path,data)
as long as ‘path’ has a value do a writefile
system.nav.closeWindow('AP7_Power_Reports/Biscuit_Report')
lastly close the window with the report on it
#system.util.invokeLater(test,1000)[/code]
Can anyone please explain how I am using the invokelater function incorrectly.
