invokeLater function problem in script Library
Can we use invokeLater function in project.scripts Library?
Because when i was trying to write values to certain tags, But it was not writing.
You might need to use a full context write, try including the tag provider in the tag path
include the code to be able to meaningfully understand the problem
invokeLater is a UI related function and only exists in the client. You can use it in script libraries but the function will only work if the invocation originates from the client/designer scope.
FWIW, I implemented an emulation of invokeLater for gateway scope in my later.py helper script, mentioned here:
and here:
Note that it uses officially unsupported methods to obtain the appropriate context.
The official method of obtaining delays in gateway scope (per IA support) is to use a sleep in an asynchronous thread. That's just ugly. Almost unforgivable. /:
If you are trying to use it for gateway, then use invokeAsynchronous
Thanks every One for your suggestions :blush:, They were really helpful for resolving my problem that i was facing.
