IOT2050 as Ignition edge
Hi ,
I'm trying to use Siemens IOT2050 basic (6ES7647-0BA00-0YA2) as ignition edge and run a perspective session using a browser on IOT2050. The problem is IOT2050 has only 1GB ram and it's not enough for running the edge and perspective session at same time.I have limited memory usage of the ignition edge to 256mb but still the same issue. Does anyone know about this problem or has any experience using Siemens IOT 2050?
Perspective is a memory hog. I would not expect it to work on such a limited system.
