IP based autologin -Vision
I would like to have the below functionality-
When a person from M-01 area launches the application, machineboard for this machine should display directly with 6 menus above. he should not be able to navigate to other icons.
Similarly when a person from M-02 launches, same applies and he will not be able to view other machine details.
This user login information can be distinguished with their login IP. for eg :if 172.16.10.90 is for M-01, 172.16.10.91 is for M-02.
Client event script Used:
ipAddress = system.tag.read("[System]Client/Network/IPAddress").value
query = """SELECT Process as Process , MachineID as MachineID FROM cdcms.tbl_ip_details where IP_Address=?"""
userInfo = system.db.runPrepQuery(query,[ipAddress])[0]
window1="Main Windows/Machine/Machine Board"
window2="Main Windows/Machine/Machine Board-East Dock"
window3="Main Windows/Machine/Machine Board-West Dock"
system.nav.openWindow("window1",{"Process":Process},{"MachineID":MachineID} )
system.nav.openWindow("window2",{"Process":Process},{"MachineNo":MachineID} )
system.nav.openWindow("window3")
I am getting below error:
In your code sample, I don't see a definition for Process or MachineID.
How to assign the results from below query to a variable.
Remove the """ from the query. runPrepQuery will pass the data as a string.
query = "SELECT Process, MachineID
         FROM cdcms.tbl_ip_details WHERE IP_Address = ?"
userInfo = system.db.runPrepQuery(query, [ipAddress])[0]
Process AS Process, etc. is redundant so I've removed the AS parts.
Still i am getting the same error
You will need to create variables and assign the values from userInfo to them.
I'm not where I can test code, but it should look something like this:
Process = userInfo.getValueAt(0,"Process")
MachineID = userInfo.getValueAt(0,"MachineID")
The user manual says the syntax is
system.nav.openWindow(path, [params])
Try,
    {"Process": Process, "MachineID": MachineID})
Mind your spacing in your code. Standard is no space before punctuation and one space after punctuation. It will improve legibility.
