IP Camera through Gateway
Hello,
I’m testing the IP Camera Viewer on Ignition 7.9.7 and tried the following in the URL property of the component:
http://<gateway ip>:8088/main/system/urlproxy?url=<username>:<password>@<camera ip>/mjpg/video.mjpg?&resolution=640x480
However I get the following error:
When accessing the stream directly on the Gateway through Firefox it works fine.
Any reason why this error might be happening? I figure it’s the connection between the client and gateway causing the issue.
Thanks.
See here: 7.7.6: No servlet "urlproxy" found
You can enable the URL proxy if you’d like, but it’s a security issue, so it’s not enabled to default.
