0sm0
1
Hi Guys,
Ignition V7.9.1
Using the IP Camera Viewer to do Jpeg Stills with the following URL works when the client or designer is on the same subnet as the camera.
http://10.30.2.60/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=user&pwd=xxxx
However when using a client that is not directly on the same subnet i use the following URL I get “IOExcetion: URL is not a JPEG image” error.
http://server:8088/main/system/urlproxy?url=http://10.30.2.60/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=user&pwd=xxxx
The URL Proxy is enabled in the Ignition Gateway config file as below and has worked previously on a different camera.
wrapper.java.additional.10=-Dvision.urlproxy.enabled=true
Just wonder if there is a reason that the Proxy might not work in this case?
Cheers for any ideas.
Tim…
Did your previous success including proxying url GET parameters? You might need to urlencode the ? and & delimiters.
0sm0
3
URL encoding did the trick
http://server:8088/main/system/urlproxy?url=http://10.30.2.60/cgi-bin/CGIProxy.fcgi%3Fcmd%3DsnapPicture2%26usr%3Duser%26pwd%3Dxxxx
Thanks for the help.
HI,
It’s a bit old topic… but i try to connect my Hikvision camera trhow the ignition proxy gateway but i get “Exceptio: Receiver HTTP 401: Unauthorized” message (I modified the ignition.conf file to enable the proxy). If i connect directly with the url “http://admin:pass@192.168.100.250/Streaming/channels/102/httppreview” it work perfect, but only with one client-designer, that’s why i’m trying throw the gateway with the url “http://192.168.100.146:8088/main/system/urlproxy?url=http://admin:pass@192.168.100.250/Streaming/channels/102/httppreview” but nothing work. Any suggestion??
Thanks!
