IP Video Camera Component
Why can’t customizers be added to the IP Video Camera Component?
They can be added but we don’t have any need for a customizer. What did you have in mind?
A dynamic URL for the video source.
I’m sure I can find a way to do it.
You can set the URL dynamically. The URL property is just like any other string. You can bind the value to an expression or query.
Trying to access Panasonic IP Camera WV-SP102E, shows error message below :
[color=#FF0000]IOException : Stream is not MJPEG stream[/color]
The URL is : http://192.168.1.10/live/index.html
On the camera setting, i disable H.264 stream, only JPEG stream allowed.
Any idea?
Best Regards
This is a common problem with ip camera. Generally, there is a link for the raw stream behind the html page.
With your regular browser, just open your url “http://192.168.1.10/live/index.html” and right clic on the image you have, select copy url and past it in another browser pane and check the result. You should have something like “http://10.0.0.33/video.mjpg”
Hope this help
