My web camera component works for awhile, then quits working. I have a Panasonic BL-C30 camera.
Clark,
What are you using for the path. For my Panasonic BL-C10A the correct URL is given below. I found this by right clicking the ActiveX control in Firefox and clicking properties.
http://IP_Address/nphMotionJpeg?Resolution=640x480&Quality=Standard
My guess as to what’s happening for you is that you’re using the browser to authenticate. In this case the session will time out eventually. On the IP Camera viewer component you should have “Use authentication” checked and have a username and password entered.
