Is it possible to copy a Perspective page from a project and paste it to another project from the designer?
Hello Forum,
for two separate projects (that are not in the same gateway), I have received like 99% specification of a page that I already have in another perspective project, is it possible to copy paste this perspective page to the new project through the designer?
Thank you.
Copy and paste should work from one designer open to another. You need to have both designers open though.
Another possibility is to export the view and import it in the other project.
See the post below.
When I copy paste Ignition tells me:
The contents in the clipboard cannot be pasted here.
I will test the second option, thank you for your response!
Where in the Project Browser are you trying to paste it? Which tree item has the focus when you get that error.
Just copy/paste the views as JSON.
I feel that I was focusing on the right path, but anyway the second way worked, thank you!
