Is it possible to create a Vision Component that is able to create Instances of Templates?
Hi all,
Looking to make a Vision Component that acts as a Custom implementation of the Template Canvas. From what I can tell this might not be possible (i.e. accessing and creating instances of Ignition Templates) but I am hoping someone might have a little insight and able to confirm whether this is in fact passed the technical limitations as I know IA obviously have to keep their in-house module source code under tight wraps.
All answers are appreciated thanks!
You can subclass the Template Canvas in a 3rd party module to create a version with custom behavior.
This is excellent news for me, is it just extending a class and if so any idea what the reference would be, etc. I tried building upon built-in modules before (or at least implementing behaviour) but was unable to see how to do so, are you able to point me to documentation as I could never find it!
Start with the Vision Component example module:
Then subclass this:
Thanks, this is exactly what I was looking for. I always did look to see if built-in components could be extended but seems I always missed this part of the docs. Thanks!
Sorry Phil,
Any ideas on the best way to deal with the BeansInfo? As I say, I haven’t extended in-built components before and this is a relatively painful one to start with. Is there a way I can essentially transfer over the Component Properties to my Override or do I need to figure out what the original BeanInfos contains and remake it from scratch?
Kind Regards,
Max
You need your own beaninfo. You can reference the original to establish a baseline and just provide the differences.
When you say reference do you mean extending the TemplateCanvasBeanInfo class? If I am just extending the TemplateCanvasBeanInfo how do I override the Constructor to point to my new component instead of TemplateCanvas.class? I.e. the equivalent of:
public class ExBeanInfo extends CommonBeanInfo {
    public ExBeanInfo() {
        super(ExComponent.class, DynamicPropertyProviderCustomizer.VALUE_DESCRIPTOR, StyleCustomizer.VALUE_DESCRIPTOR);
As I know that the TemplateCanvasBeanInfo already extends CommonBeanInfo, I have never met a situation where I need to change something like this.
No. Extend CommonBeanInfo and implement getAdditionalBeanInfo().
You could also create instances of TemplateHolder in your own custom component, if whatever you're trying to do doesn't work well as a direct subclass of the existing template canvas component.
If you do this, be sure to call the lifecycle methods when they are called on your outer component, plus when dynamically adding/removing on the run. This is required to start/stop the template's nested bindings.
