Hello all,
I have a Table component that I am using to display SQL data. I plan to use column selection to aid me in manipulating the data. The problem that I am having is that I do not want my users to be able to select the first column. I have tried to find a selection element in the column properties but there is none. I have also tried to use an onClick event on table to detect the selectedColumn and deselect it if it is the column in question. But I am receiving and error when I do that.
This are the different things that I have tried:
event.selectedColumn = None
event.selectedColumn = "None"
event.selectedColumn = -1
This is the error that I am receiving:
AttributeError: 'com.inductiveautomation.ignition.common.script.ada' object has no attribute 'selectedColumn'
