Is it possible to pass in a parameter into runScript() function?
I have created a script where I have defined the method for converting a string into date. Now, I want to use this script in an expression binding for a label using "runScript()" function. I want to pass the text of this particular label into this runScript as an input, but I am getting an "Error_ExpressionEval" error. Attached below is the screenshot. Can anyone help in solving this?
Hover over the error?
Hi, thanks for the reply. If I hover over the error, I am not getting any error message
Look at your gateway log to see if anything shows there. If not, consider adding a try: -- except: block in your called function to capture and log any errors in the script itself.
It might be too late now, but I'd also suggest to have a look at the Python naming conventions PEP 8 – Style Guide for Python Code | peps.python.org
Generally:
  • classes use PascalCase
  • functions, variables, and library names use snake_case
  • constants defined at the top of script libraries should use ALL_CAPS (and should never be modified from their init value)
jython is so dominated by the JVM it sits in that I prefer java's camelCase for functions, methods, variables, and libraries.
Wouldn't this create an infinite loop since you're passing the text value of this binding into itself as a parameter of your runScript? Are you intending to use a different value from some other component to pass into your script instead?
@Visveswaran_Dharmara the answer to your question is yes you can pass in parameters
as a test, I made this quick function:
Then in a perspective view custom property binding I did this:
I would suggest you look at your actual function definition and make sure the issue is not there.
RE: style
I'm in full agreement with @pturmel there is so much in Ignition that is built on java that you cannot control so camelCase is the way to go to avoid having a messy mix.
Cheers,
Nick
EDIT: I figured it out.
Bottom line, there is something wrong with your script, but for some reason, the error tracing when you use the runScript expression isn’t very good. I had this same issue, but what helped me was to temporarily change the binding to a script binding and invoke my function from there. When I did that, then I got more specific information as far as what was wrong with my script. Once I fixed my script, I changed the binding back to an expression transform (in my case it was a map transform with expression outputs, but same difference), and then the runScript expression worked.
You have to pass the function call in as a string. So make the string first using the parameter and then pass the entire function call to runScript().
Don't do this. The first argument to runScript() should always be a constant. The execution time of runScript() explodes if this string changes from execution to execution. (Not to mention the quoting trials when needing to pass non-numeric values.)
I guess I’m not familiar enough with runScript to know how to use it outside of just using a (constant) string. That’s what I always do. I had assumed passing the parameters as strings would be the same. Listen to Phil.
