Ignition 8.0.16
In the Schedule Tab on a Report, is it possible to reference one parameter with another parameter? I have added a screenshot because I can’t think of another way to explain it. I have tried with curly braces but it’s trying to process as a regular tag. I have tried using @ and ? with no luck.
That didn’t help. I really need to be able to reference that parameter on the Schedule tab. Referencing another parameter on the Data tab works fine by using curly braces { } but the Schedule tab keeps trying to evaluate anything between curly braces as a tag instead of a Report parameter. Any suggestions?
The schedule is used to kick off report execution, so it not accepting a parameter that won’t exist until it executes is to be expected.
This doesn't make much sense. Whatever expression you put on one can be put on the other. If the expression has side effects, put it on an expression tag and use that tag.
Thanks @pturmel. I understand what you’re saying about the parameter not existing until execution. That makes sense.
I was trying to figure out a way to make a Scheduled report a little more dynamic.
For instance the StartDate and EndDate. I have a few Schedules for the same report and the tagpath to my bound StartDate and EndDate tags changes for each schedule. I was trying to avoid explicitly typing a different tagpath for each schedule.
Don’t use the schedule and do it with a gateway event.
Then you can loop through or build any param set you want and make as many copies or whatever you want.
