Is there a central Ignition SSL keychain available?
Hi all,
I’m currently working on integrating support for Secure AMS into my Beckhoff ADS driver. Here there are 3 types I can use: Officially Signed Certificates (not an issue), PSK (Pre-shared-Key) and Self-Signed-Certificate. While for the first I obviously don’t need any setup and for the PSK version I just display two input fields, for the SSC I would need a java keychain plus some input fields.
Now I was thinking, I assume the OPC-UA driver supports TLS secured communication, so ignition probably has a keychain in place. I would like to re-use that for my driver. The alternative would be to auto-generate one, if none is provided.
I guess generating one on the fly would not be a huge problem, I just thought re-using what’s already there would be easier.
So … Is there an option for modules to access an official Ignition keychain for TLS transports?
Chris
There isn’t a centralized KeyStore or certificate management function/area, though it’s something we’ve talked about. Currently each area of Ignition that needs certificates/keys manages its own.
Ah ok … thanks … then I’ll continue down that path … is there a default storage convention where modules are to put their data (such as p12 keystores?)
From GatewayContext, get the SystemManager.
In 8.1, you can get the data dir and then use something like $data/$moduleId/yourfiles.
In 8.3 SystemManager has methods like getModuleConfigDir() that you would want to use instead.
Perfect … thank you :slight_smile:
