Hi I'm a ux/ui designer with front-end experience in Angular. I'm interested in the SCADA/HMI field and wanted to ask if a designer/front-end developer who specializes in CSS is something the industry actually needs, or if these roles are aimed directly at engineers.
Cheers
I would think so. It's actually an area of programming where AI is no substitute for a human.
I would think so too.
Being able to make high quality user interfaces is a valuable skill. It's important to understand the engineering side as well because your UI could be controlling physical equipment but there is a benefit to solid UI design.
Be aware that Ignition is built with React, not Angular. You will have to make at least that adjustment.
I'll add, I'd consider looking more towards integrators and/or module developers instead of just a manufacturer that uses Ignition.
Not saying there's not a market for UI Designers in standard manufacturing (my opinion is that there should be), but based on my time in the space, integrators who are building platforms and tools they are looking to sell are going to care more about a good UI for marketing purposes than the plant itself, where the functionality is typically the finish line, not a marketable product.
But in the end, ideally, the project has both function and form.
Definitely is a place for them. Us engineers don't generally have a great eye for what is great from a UI/UX standpoint. So it may WORK, but it may be painful for the end user. In my prior role, I tried to separate the 2 functions out so backend was the controls guy, but the frontend was handled by my project mgr who had a graphics background. She came up with stuff like color-blind friendly color schemes since it was a predominately male workforce (and ~10% of males are red-green colorblind).. And she worked directly with the endusers to make sure the screens had the actual functionality they needed.
Your not wrong. And there definately should be. The issue is many manufactures are not in a place where they can employee someone to soley work on UI/UX. They need someone who is multidisiplned. Who can go from working on a UI to troublshooting a PLC.
I think there are also a lot of manufactures that either do not know or do not understand the impact that poorly designed interfaces can have on the efficiency of a production process.
So often I present a high-performance solution and the facility proudly declares that they want a P&ID that's been dipped in a rainbow. Just trying to change operator's minds about what works well can be an uphill battle.
