Hi, I am trying to setup Ignition on AWS cloud. I am following this Ignition by Inductive Automation on AWS
Deploy Ignition into a new VPC
However, I am getting some errors, wondering if the parameters I added are correct. Is there any step by step guide for this?
Note: I am NOT looking for "Ignition cloud edition"
Hello @Shivam_Mathur,
Based on my research, the guide you have linked is the current documentation available from our end for setting up a Standalone or Cluster deployment of a Standard Ignition server for AWS EC2 instance.
Since you are running into errors by following our guide for AWS, I would recommend opening up a support ticket with us so that a Support Engineer can help you troubleshoot this further.
https://inductiveautomation.com/support/home/
