99.9% of the time when I am interacting with the tag browser, I want the tag path. But my default drag and drop spits out the whole tag json (specifically into a SFC action script editor, in this instance). ctrl+c on the tag in the tag browser and ctrl+v in the editor does nothing. I want both of these to default to the tag path. Is that something I can arrange? Maybe another hotkey? I don't see anything obvious in project settings.
Are you referring to the tag browser in the designer or the tag browser component in the client?
All in the designer
There is no GUI provided way to assign a short cut key, or change the function of an already existing one.
The only way I know of the copy the path of a tag from the tag browser is to right click and select copy Path.
Well, that is a bummer. I never use the default copy paste behavior of the tags in the tag browser, I nearly always want the path to the tag.
