Is there a way to delete a table from internal database
Hi there.
Trying to find a way to delete a table from internal database.
http://localhost:8088/web/status/sys.internaldb?39
Some one get any idea? :disappointed_relieved:
drop table TABLENAME
Be careful you don’t delete anything important. Make a backup first.
Thanks, it works.
Appreciate your help :+1:
I’m going to hope on here, but I am trying this line to clear out some databases I made while doing some module development testing but am getting an error and the tables aren’t getting removed.
ā€œsimpleorm.utils.SException$Jdbc: SQL: drop table AAREADERCONFIGURATIONSETTINGSā€
A simple DROP TABLE tablename works in my case.
If you are doing this with the web utility, you will have to make sure no trace of the module’s PersistentRecord definitions are hanging around. A complete gateway restart may be necessary to clean up loose ends (with the module already removed).
Also consider shutting the dev gateway down and using sqlite3 outside Ignition.
Restarting the gateway did the trick. Thanks.
