Is there a way to turn off alignment guides in Perspective?
They can be distracting when there a lot of objects in a view and several guides are generated, and possibly even slowing things down with all the calculations being done. Any help would be appreciated. Thanks.
Working with Perspective Components - Ignition User Manual 8.0 - Ignition Documentation (inductiveautomation.com)
In the vision, I know that you can just right click on each of them and remove it. I do not know about perspective but that might be the solution for that too.
I would be interested in this as well, as it can be difficult to place objects sometimes with the mouse
It’s not the same as a global ability to disable, but if you hold down Alt while moving all rulers/snapping is disabled.
Thank you, this dramatically improved the responsiveness of clicking and moving objects in the developer. If I could make a recommendation, I would suggest making the functionality reversed. The rulers/snapping are off by default, and alt will toggle/enable it.
I have added it as feature request for anyone interested:
Allow user to toggle rulers/snapping in Perspective without having to hold Alt | Voters | Inductive Automation (canny.io)
I had a feeling it was something like that
It helps, but still there should be a way to turn it off.
