Is there a way to view the system Id (SystemInfo.get().getSystemId()) In the Ignition UI somewhere?
Im not finding it anywhere except through the API.
Thanks in advance!
You can put it on a screen somewhere if you want, but otherwise no, it doesn't look like it.
This is kind of a "behind the scenes" value, not something you really need to see.
Thank you
Does this system id string have a format? (such as length) or can it be any string?
I think it's SOMETHING:SOMETHINGELSE... not sure if that's true on all OSes, and it's not part of the API so it may change in the future if necessary.
thanks!
Is there in the public API a function to get a property that uniquely identifies the ingnition install?
Maybe the system name or UID, from the system properties (GatewayContext::getSystemProperties).
Thank You!
