We would like to run a DB script that does some updates to the database tables before we load them into our application. Is there an “on load” type event we coud use?
On load of a project or a window?
For the project: use the global startup script
For a window: Use the window’s internalFrameOpened event for when the window is first loaded, or internalFrameActivated for when it is opened (even from the window cache)
Hope this helps,
