Is there no trial version for ignition 8.3.6
hi, all
today I upgrade my ignition to V 8.3.6, there are no trial version for this version? just show certificate has not been accpted
and all modules are not working
It looks like the certificate for the modules has not been accepted which is strange.
Could you open up the menu on the right side of one those modules and see if there is an option to accept the certificate?
Quick test of an upgrade from 8.3.4 to 8.3.6 had no issues with the Trial version or the Modules. Also, new Install had no issues. More information would be needed to further assist.
While we are not seeing this issue, I want to understand how your Ignition instance ended up in this state. In addition to what William asked for, can you please provide the following:
  1. What Ignition installer did you use (Installer, ZIP archive, Docker)?
  2. If not using Docker, what OS did you install Ignition on?
  3. If using Docker, what are your mapped volumes?
  4. What Edition of Ignition are you using (Standard, Edge, Cloud, Maker)?
thanks for all your teams quick support, I try to reinstall V 8.3.6 again based on above situation, and disable all modules then enable all of them, fortunately it works, and the precondition is I installed the Version 8.3.5 firstly, I upgrade it to 8.3.6 while received your email about 8.3.5(there are some notable aggression)
