Is there a grid you can activate on Ignition Designer?
That feature is available in Ignition Vision. To activate the snap to grid feature you can use Ctrl + G, or snap to guides Ctrl + Shift + G. Other properties are available in the View section.
If you're using Vision, it will look like this:
