I have a script that runs on the property change event to update an SQL tag. The PLC is connected wirelessly. I have it in its own scan class to account for the slower comms / latency. Most days, this is good enough to prevent overlays and errors from popping up in the writeToTag script. Some days, it is not. The script runs every few seconds and on the bad days can be quite annoying with the error popup window. My sloution was to use an ‘if’ in the script. The property change event fires as often as it did before but the writeToTag only happens ‘if’ data quality is GOOD. The way I see it, the SQL tag would not get written when data quality is BAD either way. I am preventing the server from attempting to write when it can not, saving some unnecessary comms. Any issues with this method?
Shawn
