Hello, General Question?
Does Ignition Edge IIoT or Ignition Edge Panel includes the Wev Development Module.
Best
Best
No.
Then, how to enable a REST server with ignition edge?
Talk to your sales contact--you may be able to use Web Dev on Edge for a fee with a custom license.
Without WebDev, and with Edge's restriction on 3rd-party modules, your only other option would be to use low-level java from jython to establish you own listening socket.
(Basically, you are going outside the general use case for Edge.)
Edit: See below....
WebDev used to be allowed when there were edge "plugins", it was enabled by the "Edge Compute" plugin.
I assume it's available now in one or both of the simplified Edge offerings as well.
Looks available to me ![]()
how to install external module to Ignition-edge ?
Download the right version of the module file, or extract it from a Zip installer. Add it to your Edge install from the Config => System => Modules page as usual.
Contact IA sales to buy the license. Possibly not necessary.
