Ignition 8.0.4 system.dataset.toCSV in US vs Belgium.
I am using the following to generate CSV for export. The project is used in both the US and Belgium with very different results in both places.
csv = system.dataset.toCSV(table.viewDataset, showHeaders=1, forExport=0, localized=1)
From the US I get:
"A1","","IDLE","",,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,"0"
"A1","4","12329","N/A : 220 : 60 ",,,,,,,,,,"1.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","3.1","63.10000000000002"
Similar lines from Belgium are:
"H8,"""",""IDLE"","""",,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,""0"""
"A1,""4"",""12443"",""N/A : 220 : 60 "",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""1,1"",""34,100000000000016"""
We are using this step to get the data into Excel because html is used in the header and I have found no good way to strip out the html without first passing through this step.
