Issue connecting to SQL Server docker instance with ignition?
I am new to docker so I am probably missing something silly.
Here is my compose file -
services:
  sqlserver:
    image: mcr.microsoft.com/mssql/server:2019-latest
    container_name: sql_server
    ports:
      - "1435:1433"
    environment:
      - ACCEPT_EULA=Y
      - MSSQL_SA_PASSWORD=SomeStrong!Passw0rd
    networks:
      - app-network
    volumes:
      - sql_data:/var/opt/mssql
  ignition:
    image: inductiveautomation/ignition:8.1.43
    container_name: ignition
    ports:
      - "8089:8088"
    depends_on: # Ensures SQL Server starts first
      - sqlserver
    environment:
      GATEWAY_ADMIN_PASSWORD: password
      IGNITION_EDITION: standard
      ACCEPT_IGNITION_EULA: "Y"
    networks:
      - app-network
    volumes:
      - gateway-data:/usr/local/bin/ignition/data
networks:
  app-network:
    driver: bridge
volumes:
  sql_data:
  gateway-data:
I am able to see and access my Ignition gateway.
I am able to login to this SQL Server instance via the SSMS on my local computer by going to 127.0.0.1,1435. I do need to trust server certificate but otherwise works.
When I try to connect to SQL Server via Ignition by making a database connection I keep getting
java.sql.SQLException: Cannot create PoolableConnectionFactory (The TCP/IP connection to the host localhost, port 1435 has failed. Error: "Connection refused. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.".)
I tried adding the trustServerCertificate=true to the connection string but still cannot connect.
I don't know what else to try or do. Any ideas?
What host name are you using in your gateway's DB connection URL? (Should be the container name, not localhost.)
I changed my container_name and added a hostname like
container_name: sqlserver
hostname: sqlserver
My JBDC conn string is
jdbc:sqlserver://sqlserver\MSSQLSERVER:1435
I am still getting the same error regarding TCP/IP.
I did notice through SSMS I need to do 127.0.0.1, 1435, trying sqlserver or sqlserver,1435 does not reach it so I am curious if it is a network thing. I have not configured the app-network at all outside of making it.
Not sure. But URLs are not supposed to have backslashes.
On ours we use
jdbc:sqlserver://localhost\MSSQLSERVER:1433
Yours should end with 1435
With the extra connection settings of
databaseName=NameOfDatabase;trustServerCertificate=true
Try with only jdbc:sqlserver://sqlserver:1435
Make sure to configure the database name in the extra connection properties
I figured it out. I stopped the SQL Service running on my local computer. I also have Ignition running locally and figured I could try connecting from that gateway. That worked - with a
jdbc:sqlserver://localhost\MSSQLSERVER:1435 and trustServerCertificate=true.
However the above was not working with my dockerized version of SQL Server. I know @pturmel and mentioned using the name, so I tried jdbc:sqlserver://sqlserver\MSSQLSERVER:1435 and jdbc:sqlserver://sqlserver:1435 but no dice.
I took a guess that this part
    ports:
      - "1435:1433"
meant from the outside I need to use 1435 but inside the docker network app-network I am using, I can use 1433 and that did - so it ended up being jdbc:sqlserver://sqlserver (without the \MSSQLSERVER - it does not work with this - thanks @pascal.fragnoud )
As a general rule with docker instances accessing other docker instances, I have been using the host.docker.internal instead of using localhost as the hostname. This essentially routes the network traffic as if you are querying the base machine for the resource, which then works as docker exposes the ports to the base machine as normal. This works when running MySQL on the same docker as Ignition, and hasn't broken in a couple of years.
Is there any explanation why my containerized database can connect successfully from SSMS using either aliasedName:mappedPort or serviceName:mappedPort, but the same aliasedName:mappedPort does not work on Ignition gateway?
In Ignition, I get the following error:
Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
Caused by: java.net.ConnectException: Connection refused
However, the connection works if I use:
  • host.docker.internal:mappedPort on the gateway OR
  • aliasedName:defaultPort or serviceName:defaultPort
Why does gateway fail with aliasedName:mappedPort while SSMS succeeds?
The MSSQL service is listening on a given port, i.e. 1433/tcp. If this is in a compose stack as service "mssql", then you'd connect to it from another service in the stack by name and port, i.e. mssql:1433. Whatever port you're using with SSMS is the port that is listening only on your host interface. This is why it will work when you point Ignition to your host interface (via host.docker.internal) on the published port. Ideally, you'll want to connect Ignition via serviceName:defaultPort (your description) instead of having it loopback through your host.
Oh ok, thank you for the explanation.
So, even if I configure 2–3 MSSQL services (each mapped to a different host port), I should still connect using the serviceName:defaultPort approach, right?
For example:
mssql1:
  ports:
    - 1435:1433
mssql2:
  ports:
    - 1436:1433
mssql3:
  ports:
    - 1437:1433
So, when connecting to two different services, I should use:
  • mssql1:1433
  • mssql2:1433
and not host.docker.internal:1435 & host.docker.internal:1436.
Yes, you've got it. Docker Compose creates a default network for your stack within which services can connect to each other. The only reason you need/want to publish ports out to your host is only for your own management of those DBs via SSMS. The port publishes aren't needed at all for service-to-service communication.
I was having same issues using //localhost and using host.docker.internal resolved it,
Thanks for this
