Issue number field
I’ve this pop up
When the operator press the OK Button trigger a script:
angle = event.source.parent.parent.getComponent('angle_num').floatValue
barcode = event.source.parent.parent.getComponent('barcode_num').intValue
callsp = system.db.createSProcCall('procedure_name')
callsp.registerInParam("BARCODE", system.db.INTEGER, barcode)
callsp.registerInParam("ANGLE", system.db.FLOAT, angle)
system.db.execSProcCall(callsp)
event.source.parent.parent.getComponent('angle_num').floatValue = 0
event.source.parent.parent.getComponent('barcode_num').intValue = 0
The problem: If I use the mouse on my pc it’s work, instead when the operator use the Touchscreen it’s like the focus remain on the number field (the last I insert) .
The behavior of my number fields are:
Could you help me please? Thank in advice
When using the touchscreen, is pressing the button itself not working?
Is it really a button component or a label with a mouse action?
What specific event are you using?
  1. the button work but the last number field that I compiled remain focus.
  2. I use a button
  3. the event is ActionPerformed.
thanks
In the project properties, do you have Touch mode enabled?
Hi, yes I did it but it’s not that the problem. Thank you
