Hello,
I’m trying to map a network drive and I have a problem.
I changed the ignition.conf by adding these lines:
The user and password is good. I can map the drive in my personnal computer using these credentials.
But it’s not working. So I set wrapper.debug = TRUE. And I saw this message in the wrapper.log file:
Attempting to map the "\hosxxxxxxxxxxxxxxxxxxxxxxerix1" share to “G:”…
Running a service as System User disqualifies the use of an account. Ignoring wrapper.share..account
Unable to map “G:”. Trying to continue. (The network path was not found. (0x35))
Do I understand the ignition service must run under a user account? I tried that at the beggining and I had issues with the databases access, or redundancy… I’m not sure. But I remember I had to run the ignition under the System account.
Thanks.
