Issue updating to 8.1.5
Hello,
Trying to update from 8.1.3 to 8.1.5. I have just run the installer. Gateway doesn't start now, here is the log file.
wrapper.log (3.9 MB)
In addition this is the log from Windows (Service Control Manager)
Try moving or renaming the ssl.pfx file before starting the gateway again.
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp:
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: Encountered an error running main:
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: java.io.IOException: Invalid keystore format
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at java.base/sun.security.provider.JavaKeyStore.engineLoad(Unknown Source)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at java.base/sun.security.util.KeyStoreDelegator.engineLoad(Unknown Source)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at java.base/java.security.KeyStore.load(Unknown Source)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.security.CertificateUtils.getKeyStore(CertificateUtils.java:54)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.ssl.SslContextFactory.loadKeyStore(SslContextFactory.java:1188)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.ssl.SslContextFactory.load(SslContextFactory.java:323)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:245)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:92)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:320)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:231)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at org.eclipse.jetty.server.Server.doStart(Server.java:385)
INFO   | jvm 1    | 2025/05/15 08:32:13 | WrapperSimpleApp Error: 	at com.inductiveautomation.catapult.IgnitionServer.start(IgnitionServer.java:1140)
Couldn't find any ssl.pfx file. Decided to uninstall and perform a fresh install. Now it works.
Out of curiosity, why to just 8.1.5 and not to 8.1.48 to get it fully updated?
I agree. 8.1.5 is 4 years old and is missing significant updates
Apologies for the confusion, it was my mistake. I got mixed up with the version numbering. I was updating from version 8.1.43 and accidentally downloaded the wrong installer, as I grabbed the first link I came across.
