Issue using system.tag.configure to add UDT instances to parent UDT instance
Hello,
I'm trying to dynamically add UDT instances inside of other UDT instances, but I'm getting the following error:
Error processing edit for tag path 'Engine/Line/Line 1/Station 1': Bad_Unsupported("The target path 'Engine/Line/Line 1' does not have item 'Station 1' for overrides, and cannot accept children tags.")
I'd appreciate some help with this. I was thinking that maybe the Station UDT needs to have the Line UDT as a parent type, but I'm really at a loss here.
import time
LOGGER = system.util.getLogger("TagCreationLogger")
def create_mcp_tags(device_name):
	tag_json = {
        "name": "MCP",
        "typeId" : "Main/MCP",
        "tagType" : "UdtInstance",
        "parameters" : {
          "plc" : device_name
	system.tag.configure(device_name, tag_json, "o")
def create_agv_tags(device_name):
	agv_count = system.tag.readBlocking(["[default]Engine/MCP/AGV_CNT"])[0].value
	for i in range(agv_count):
		tag_json = {
            "name": "AGV {}".format(i+1),
            "typeId" : "Main/AGV",
            "parameters" : {
              "agvNumber" : i,
              "plc" : device_name
		system.tag.configure("{}/AGV".format(device_name), tag_json, "o")
def create_line_tags(device_name):
	line_count = system.tag.readBlocking(["[default]Engine/MCP/Line_CNT"])[0].value
	for i in range(line_count):
		line_name = "Line {}".format(i + 1)
		tag_json = {
			"name": line_name,
			"typeId": "Main/Line",
			"tagType": "UdtInstance",
			"parameters": {
				"lineNumber": i,
				"plc": device_name
		line_path = "{}/Line/{}".format(device_name, line_name)
		system.tag.configure(device_name + "/Line", [tag_json], "o")
		station_count = system.tag.readBlocking(["[default]Engine/Line/{}/TotalStations".format(line_name)])[0].value
		create_station_tags(line_path, i + 1, device_name, station_count)
def create_station_tags(line_path, line_number, device_name, station_count=10):
	for i in range(station_count):
		tag_json = {
			"name": "Station {}".format(i + 1),
			"typeId": "Main/Station",
			"parameters": {
				"stationNumber": i,
				"plc" : device_name,
				"lineNumber" : line_number
		system.tag.configure(line_path, [tag_json], "m")
		print("Station {} Configured at path {}".format(i+1, line_path))
		LOGGER.info("Creating station tags at path: {}".format(line_path))
def create_all_tags(device_name):
Thanks in advance.
Ignition doesn't support this at all.
You must change the definition to include more members, and all instances will get the new members.
UDT instances are not folders.
Thanks, as always!
My solution will be to create folders for each line, under which the "Line" UDT instance and the "Stations" belonging to that line will exist. I would change the definition of the Line UDT if the number of stations in a "line" were static.
