Issue with connecting Python OPCUA server with Ignition as a client
I wanted to establish a secure connection between my python opcua server to ignition,
hence i tried connecting my python server with python client hence its working fine but the same when i tried it using ignition it not working and im getting this unable to find valid certification path to requested target error
io.netty.handler.codec.DecoderException: UaException: status=Bad_SecurityChecksFailed, message=sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Could you please assist me in resolving this issue? your support is highly appreciated.
Regards,
Sri Haran S
Tip: use the </> button to format code blocks, not the ” (blockquote) button. More here.
This is ambiguous. Do you want Ignition to act as the server or the client? (If the latter, a native English speaker would say "from Ignition".)
That said, your error indicates a mismatch between Ignition's security expectations and your python implementation's expectations. This is normal, at first, when one or both sides require certificates, and "accepting" the certificates isn't complete.
There's a section of Ignition's gateway web page where remote certificates can be accepted. How it would be done on the python side is up to you.
