I am trying to use cutaway image 18 as it most closely resembles the bins we are filling but the level indicator does not show correctly behind it. I may use the other one for now but is there anything that can be done to fix this?
It is because image 18 is slightly transparent. If you put the image over any component you will see the component through the image. We would have to redo image 18 with no transparency to fix it.
Thanks for bringing this to our attention. The source graphic has been fixed. I’ve attached the new graphic here - you can download it and overwrite the faulty one with this one and you should be all set.
Hope this helps,
Excellent, Thank You
