Issue with date retrieval from database?
I picked date using datetime input component and saved in database:
now when I am retrieving it using following query to perspective table its showing wrong value:
SELECT expense.expenseId,
expense.employeeName,
expense.description,
expense.job,
expense.cdnTotal,
expense.usdTotal,
expense.euroTotal,
expense.expenseDate,
expense.selected
FROM expense
Thank You
You’ll need to configure the props.columns section of your table. The props.columns[x].field should be equals to the column name, set your props.columns[x].dateFormat as you like and if needed, force the props.columns[x].render to date.
Since data is fetched from database there is no props.columns
i added columns and tried still not working
The props.columns can be auto generated by your dataset with the system.dataset.getColumnHeaders. If you want to have some flexibility on your table, the columns attribute is the way to go.
You need to set the field with the column’s name.
Thank You so much you solved my two issues with this.
