Hello everyone,
I'm writing to you regarding the problems I've encountered when connecting the DNP3 to the ABB RTU560.
Initially the connection worked fine for several hours, but now it has stopped working. The status of the device is "Connected", while the tags have the status "Bad, not connected".
I had restarted the driver as well as the gateway itself, but these actions did not restore communication
In the Ignition logs there are the following entries for this connection.
The connection to the device made from the DNP3 debugging software works fine.
Edit:
As I write this post, the problem has ceased and communication has been restored automatically, without any changes in configuration, nevertheless I would like to eliminate this problem in the future.
