Issue with expression on tag
I also encountered this problem. Has it been solved?
@XY_W I moved your post to a new topic, because the two year old post you resurrected covered a lot of different ground and you gave us nothing to work with.
Start from the basics:
  1. What is going wrong?
  2. What is your evidence it's going wrong?
  3. What version of Ignition are you using?
  4. If you're authoring any code, post the full code here as preformatted text
  5. If you're seeing any error messages or logging, post the full error(s) here as preformatted text.
