Hi all,
I'm experiencing an issue where both the Gateway and Maker Edition Designer fail to log in, which forces me to reset my password.
I'm currently working with Ignition on a virtual machine (VM). When I first start the VM, the auto-login to the Gateway works fine. However, when I try to open the Designer, it fails to log in. If I then log out of the Gateway and attempt to log back in manually, the password is rejected.
Interestingly, I was able to use the same password for about a month before it failed again. I reset the password just two days ago, and now it seems to be failing once more.
Has anyone else encountered a similar issue or found a solution?
Thanks in advance!
