Issue with java.net module import in Ignition V 8.1.5
Used Module “java.net” for InetAddress for pinging the IP address from the Ignition installed PC. Was working well for ignition version 8.0.16. But, after upgradation facing problem/error for new version 8.1.5.
Tried both upgradation and fresh installation of the version 8.1.5
What is the error? Can you post a stack trace?
from java.net import InetAddress
timeout = 5000
device = InetAddress.getByName(address)
ping = device.isReachable(timeout)
if ping == 1:
Print “Device Reachable”
if ping == 0:
print “Device is not Reachable”
As a Output of this script is “Device is not Reachable”. without any error means, its not able to ping the IP address which is connected.
I read below doc and found some details related to the firewall and server configuration blocking.
URL -InetAddress (Java Platform SE 8 )
If on Linux and not running as root, use of any ping-like raw packet requires the CAP_NET_RAW capability (privilege). You can specify that in the SystemD service file (or override) with the AmbientCapabilities=CAP_NET_RAW setting. You can specify multiple capabilities with whitespace. I recommend AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_NET_RAW.
I run a script that is essentially the same and it works just fine, never broke with upgrades. (1.8.16)
Hello @djs,
Thanks for the updates. the problem was with firewall.
No for me it is also working fine.
@pturmel, thank you for information.
